heirloom hamlet life my way Joined Feb 3, 2020 Messages 341 Location Savannah, GA Jun 21, 2020 #1 Anyone know what a BMS amp rating is based on? Is it the amps pulled by your load...or the charging amps, or inverter amps. Which amps?
Dzl Unofficial Forum Librarian & Perpetual Newbie Staff member Moderator Joined Dec 10, 2019 Messages 5,108 Location West of the rockies Jun 21, 2020 #2 ecualibrium said: Anyone know what a BMS amp rating is based on? Is it the amps pulled by your load...or the charging amps, or inverter amps. Which amps? Click to expand... As I understand it, the BMS amp rating is the maximum current that will pass through it at any given time. The higher of: Total AC and DC loads including inverter inefficiency Total charge current Also many people here consider it a general rule to de-rate the claimed output of cheaper commodity BMS' by 20-50% maybe even more in some cases. Last edited: Jun 21, 2020
