Hello group,
I have a Growatt 24v 3k AIO and two SoK 206ah Lithiums in series. I have a battery monitor hooked up via shunt and a battery balancer from watts24/7. Everything has been working fine for about 3 months. As of yesterday the battery monitor said I used about 60% battery power in 1 day. My normal usage is 20-30%. I did charge a few RC truck batteries so I thought maybe that was it. Today I used my generator to charge back up to 100%. Paying more attention tonight I saw the batteries were at 84% after charging the RC truck batteries again. I thought maybe that it was actually pulling a good bit. I monitored the battery monitor every half hour as we watched TV. Just the Growatt, TV and wifi router pulling any power and I was loosing about 5% every 30 minutes which is nuts. It's currently reading 26.2 and 66% on the battery monitor with everything off other than some LEDS. The batteries haven't settled as the TV and inverter were just on.
I disconnected and tested each battery and got 13.12 and 13.13 so they appear to be in balance as I thought that might be the issue as first.
Any ideas on what's going on with the batteries? I can normally watch TV for 4-5 hours and only loose 10%.
EDIT: On a side note I just moved campsites. I did notice the following. I turned on the Radio while I was setting up. When I used the power jack on the tongue it would turn the power to the radio off which I thought was odd. I had never turned the radio on during set up before so this was new. Is it possible there is a loose wire somewhere on the RV that is bleeding power even though nothing is connected?
TIA
TIA
