frankz66
Hello everyone, I wanted to know how to calculate the full charge time of a c100 110 amp 12 v AGM battery. In the morning the charge takes place with an initial absorption of 8 amperes and reaches up to 19 amperes in peak solar hours. I know there are three phases of charge, boost, absorption and float. The behavior of the battery is always the same ie it absorbs almost 2 A, but clearly its charge I assume is around 70%. Considering that as far as I know, it takes a long time to get from this percentage to 100%. Is there a way to calculate it? Does the float phase trigger to perform the charge action from 70% to 100% ? Thank you .
