The battery should have BREAKER for over current protection, it will be enough to protect your system. but, MUST BE A BI-DIRECTIONAL DC Break, some battery supplier use AC breaker, and it will have huge delay to trip under over-current fault. and then, need a FUSE.
Note, The most DC breaker is the uni-directional, but, the breaker of battery pack should be bi-directional because charge/discharge (bi-direction), when use uni-directional breaker reversely, it can not cool-down arc while breaker is breaking a power under load, can cause a fire. to avoid the directional issue, the pack maker use an AC breaker. there are two issue, the arc from DC is much stronger than AC, breaker may not cool-down it and cause a fire. and, over-current fault is relay on the heating & bi-metal switching, it is delaying the breaking speed.
