Really depends where you are and where your batteries are to not use any heating at all.
I have 8 inches of rock wool / mineral wool insulation (which I'd recommend everyone since it won't catch fire, ever)
Still need 20watt pad under it all to heat it. I just use a plastic lizard heater that was $5 or something.
I prefer the lizard pad which draws 23.8 watts (rated at the 20 stated above) to the light bulb method. but lights work too. Incandescent is getting rarer and rarer though. Used to use a 300 watt one for my pump house for pool back in 1990s lol
4000 ft ele on a mountain..it’s 29 outside now…will be colder about dawn.. the system and batts is at 56 degrees…im only drawing 2.28 amps at 24v according to the BMV unit using 61 watts. That will get me through the nite …simply Running the multi+ and a couple of lights some other low draw gizmos , and a small Walmart fan…
the system is almost off and it will stay around 50 all night with no other heat than what the Victron stuff and batteries produce …the fan keeps the temps evened out inside.
yes, each set up is different, every ones build is unique…very little is universal …but for my system I have learned how much I need to ” work “ the system to generate the heat I need to warm the batt bank.
if it we’re getting a lot colder I simply use more energy , which make the components generate more heat…if I hook up a 20amp load on the batts for some use I need anyway ( a small space heater for the shed or floodlights near the RV..it will keep things warm down to about 10F outside…30 amps even more heat…40;amps an ass load more…
now if it was daytime sunny and 0F… and charging at 50 to 100 amps and using a good load too , it would be 60 inside the trailer.. maybe 70 …..???
it’s not perfect , but it’s free heat.. , and works for my set up…
if it ever gets really cold -25F or somthing or I need help to heat stuff , I will simply put a small 400 watt space heater inside to cycle off and on at about 50 degrees ..or a small btu Mr buddy propane heater…
there’s always a way to rig up what ya need if ya have a lot of random resources laying around…no biggie…
it always good to have multiple layers of back up..
J.
