Hey all, I have 9 48v battery packs (with the new jk bms on each one) for my 3 eg4 6000xp inverters. How do I hook these up to the inverters (new system and learning, starting the install process now). Do I run them to bus bars, a negative and positive and from there to each inverter? Is this how you should wire them? Or should I run 3 packs in parallel to each inverter?
Thanks!
Thanks!
