My system is;
Panels- 2kW (2S-5P)
SCC- Victron 150/60
24v-100Ah (two Battleborn batteries in series)
Battery Balancer- Victron
Inverter- Multiplus 24/2000
Today, at around 12:30 PM,, various alarms went off indicating low voltage and battery imbalance.
Here's the battery imbalance screen shot;
![imbalance.png imbalance.png](https://diysolarforum.com/data/attachments/228/228990-dd1834607ece76d99aaa104ea73630c7.jpg)
Here's the "mid-point voltage alarm;
![midpoint alarm.png midpoint alarm.png](https://diysolarforum.com/data/attachments/228/228991-69762ef0ee783df04ea376b6262058e6.jpg)
The Victron battery balancer activated and made an effort to bring the "Bottom battery" back into balance with the "Top battery". I called Battleborn, talked with their tech, and, as it was supposed to happened, the imbalance voltage difference was reduced to where the Battery balancer shut off. Notice the huge (to my thinking) voltage difference between the two batteries. At one point the Bottom battery was over 15v.
I have no idea what the "Mid-point voltage alarm" is about. I assume that reflects the BMV figuring there's a difference between the two batteries.
This is a screen shot of the batteries about two hours later;
![1721155234100.png 1721155234100.png](https://diysolarforum.com/data/attachments/228/228993-30023e88995c7dbedd47df6e39b2c251.jpg)
Is what happened (a large imbalance at the batteries) a cause for concern....more than usual?
Thanks.
Panels- 2kW (2S-5P)
SCC- Victron 150/60
Thanks.
