WilliamC
- Feb 22, 2020
- 61
We have a small cabin where we experience frequent power outages. I have almost everything covered except the water situation. Power goes out, No water.
Not sure about the exact pump specifications, but I can safely assume less than 800 Watts, or 3.5 amps not counting starting load.
Would like recommendations on components to power the well. Needs to be 120v and 240v output. for battery voltage I'm thinking 24vdc or 48vdc. leaning towards 24vdc. I like the all in one concept of a combined inverter charger, but am open to ideas.
Expanding into solar is a future plan.
I also need recommendations on Battery type
This system will remain plugged in and probably only be used when the power goes out.
So I don't anticipate frequent cycling except when the power is out.
Been watching with interest the vids on building my own LifePo4 battery.
Is there a do everything BMS that has the low voltage cutoff, and High voltage cutoff and sensing and temperature cutoff and balancing and anything else one can think of in a BMS?
Im researching all of this slowly but its hard not to be swamped in marketing language, or to know what is being hyped and what is being left unsaid.
know what I mean?
know what I mean?
