Battery Monitor Connection Question
bear0214
Montana, USA
I have a new Renogy 500A monitor I am installing, along with a Renogy 40A MPPT controller, a 2000W inverter, flooded LA batteries, and 250W solar panels.
I've installed all system negatives to the P- of the monitor shunt per the install manual.
My question is: Do I also connect the negative wire from the solar panel to the P- of the monitor shunt?
Or, do I connect the negative wire from the solar panel to the PV- of the 40A MPPT SCC?
Thank you for your help.
John in Montana
