I have two old 14s 1kwh LIIO batteries that I want to connect in parallel. The batteries already have their own internal balancer, so I am not worried about individual cells. Also, since I am connecting the two packs in parallel, I suppose there is no need to balance them.
The packs don't have any kind of over/under voltage protection, current limit or temperature protection.
And here is my problem. I keep looking over different types of BMS products and all of them seem to have balancing features that require linking the individual cells. For example a 20s BMS has 20 wires to link to the cells, plus the two main terminal wires.
I only have access to the battery pack 48V +/- terminals (the cells are encapsulated in the pack).
In my case I need a simple BMS or some other device that has only two terminals. The BMS should support support 48V, ~150amps and at least the voltage and current protection.
First of all, since I don't have much experience with batteries, is this setup feasible? If it is, what kind of BMS or similar product could I use in my case.
