superjagger
- Sep 19, 2022
- 4
Hi all,
I have an odd issue where my battery discharges, even with full sun. The problem only occurs when the inverter is under load (think an average of a constant 100 watts).
The charge controller seems to not supply enough amperage to the battery when the inverter is on in order to keep the battery topped up. Once I shut the inverter off, the charge controller is able to charge the battery to full fine.
This AM I was pulling 75 watts constant off the inverter, yet my charge controller was only allowing ~3amps to the battery (3x13.8 = 41.4 watts) not nearly enough to avoid pulling from the battery bank.
I've seen this same system charge at 10+ amps when not under load.
Inverter and Charge controller are wired directly to the battery, separately. (Inverter 6 AWG - Good till ~575 watts) (CC using 10 AWG, good for 20 amps)
There is a considerable distance to travel the CC is approximately 50 feet from the battery. Inverter is on a 2ft cable.
Do I just have a crap CC? Any suggestions/ info welcome. I'm looking to learn more and improve my setup.
Thanks,
J
Thanks,
J
