I will be using a Bluetti AC200 and plugging in shore power directly to a 110v outlet on it. However when traveling I want the option to charge from the invertor 110v outlet in the house system. (Basically charging the Bluetti through the alternator when running down the road.)
Side note: I may need to upgrade the old invertor in the house, it's not pure sine and is only 400w. The Bluetti is rated at 410w from what I've seen. Afraid I'll kick the old invertor out for over voltage.
But original question... Where is the best connection point to the AC/DC fuse box/breaker panel? My concern being putting power back into the shore line when unused. Do I need to put a switch inline to bypass the shore line connection? (I don't want to spend the $ on a auto transfer switch) A manual switch wouldn't be a problem I'd switch it from outside shoreline power to inside Bluetti power. Just looking for the most efficient/safe way to power from the Bluetti inside or out and keep the system portable.
Clear as mud? Thanks in advance.
