I had run into a similar issue but not sure it is the same issue. Were you by chance simply testing EB to see if the solar works or did the battery actually needed charging? To share with you what happened to me. I was testing my power station to see how much input i will get from my potable solar. I wasn't getting any input at all.
After scratching my head a bit and some deep thoughts
realized that the battery was at 99% charge and so I brought it down to 95%...voila, the solar panel started pumping 170 watts.
