D Deleted member 9967 Guest Aug 23, 2020 #26 Remove the BMS by simply unplugging it. If the batteries then work then you may need to replace the BMS yes.
B BennySteen New Member Joined Jan 5, 2021 Messages 2 Aug 3, 2021 #27 SherylinRM said: Remove the BMS by simply unplugging it. If the batteries then work then you may need to replace the BMS yes. Click to expand... old thread but it helped me to change the cell voltage larm level a small bit and then reset.
D Deleted member 9967 Guest Aug 3, 2021 #28 BennySteen said: old thread but it helped me to change the cell voltage larm level a small bit and then reset. Click to expand... What did you change it from and what did you change it to? And old thread or not. Any input that is helpful is very welcomed.
B BennySteen New Member Joined Jan 5, 2021 Messages 2 Aug 6, 2021 #29 SherylinRM said: What did you change it from and what did you change it to? And old thread or not. Any input that is helpful is very welcomed. Click to expand... "cell volt high protect. I changed it from 3.50 to 3.52 and then a reset . This got the alarm clear away. Attachments Screenshot_20210806-123305.jpg 80.3 KB · Views: 3
D Deleted member 9967 Guest Aug 6, 2021 #30 Wow, BennySteen said: "cell volt high protect. I changed it from 3.50 to 3.52 and then a reset . This got the alarm clear away. Click to expand... nice catch there. Thanks for the insight.
