I just installed my new EG4 6000XP inverter connected to 2 used Tesla model S battery modules and about 5KW of Solar panels.
Have been able to connect the inverter to the new JK BMS, charging algorithm works flawless as far as i can tell. ( Battery Model 2 in inverter settings)
The inverter is NOT connected to the grid.
Inverter randomly goes into aforementioned error mode, W028, shuts down for 5 minutes and then boots up again.
This happens at any given load, did it twice during the evening with only 200Watts of load, just when the sun was setting. Once the sun set and it is on battery it runs happily all night and also handles high loads without problem.
I also use the inverter to charge our Tesla during prime solar hours, also here the inverter shuts down randomly at different Ampere settings, it happens most often around 12 Amps with full sun available (around 4KW), yes i am using both legs for this, 240Volt AC.
I am unable to identify any pattern other than its always happening when the Mppt is producing Solar energy and the battery is in the Zone of Zero load, shifting between charge and discharge currents.
In order to isolate the problem i disconnected the BMS and switched the inverter to lead acid Battery, problem remains.
I also removed all other loads from the inverter other than the Tesla, it still happens.
Same with car charger disconnected and only the house running.
The inverter and Breaker panels are properly grounded/bonded, installed in a 40' container.
I contacted EG for and Solar Pro guys for advice but got no response so far.
Posted this here to see if anybody else faced the same issue.
