JD McGyver
- Jun 20, 2022
- 13
Hello,
I have several EG4 Lifepower 48v server rack batteries.
Looking to use one of these to extend the battery for a smaller Portable Solar Power Station (Oukitel/FFPower P2001).
It takes 500W Max with 12-48V 15a input.
The Lifepower 48v outputs 51.2 to 56v (to the best of my knowledge), which will fry the p2001.
Can not seem to locate a suitable solution. Can you folks help?
As a minimum, it would need to take anything 48-56+ V and convert down to 48V or slightly lower.
Are there any adjustable units that are both a boost and step-down converter? I do not mind spending more for something that can be used for other tests.
Thank you.
Thank you.
