Hi,
I've got 6 x Enersys 170ah AGM that I want to connect in parallel via bus bars. I can't figure out what amp rating the busbars and cables will need to be to handle the load. Is it:
A) +170 amps
B) 6 x 170 = 1020amps
C) half (A) = +85amps
D) half (B) = +510amps
E) something else???
I am planning to connect each terminal to a bus bar via fussed cable, all negatives on one busbar, all positives on another, and then a cable from each busbar (+/-) into the appropriate connector (+/-) on the controller. My thinking is this will allow for a well balanced setup but i incisor need to know it is safe and that the conducting media is spec'd right. Apologies if this is a dumb question, and thanks in advance for any support.
Cheers
A) +170 amps
Cheers
