farmhand
- Aug 26, 2022
- 232
So what starting building a solar power station 2years has now brought us to this:
(24) HQST 12v 100w panels with a clear southern view in Ohio. 12 Poly & 12 Mono.
(6) strings fed into a 6 string combiner box, reverse diodes, surge, fused.
Then into a 32amp fused Siemens disconnect.
Then a 50' run from the coop building in 3/4pvc using paralleled #12 THHN into the most sturdy outhouse.
Then a 100A 2400w charge controller.
That's where I'm at now. Next will be the batteries. I plan for 4 SOK 100Ah (24v bank).
From the outhouse I have a 100' run with an existing 12/3UF.
I also have a huge 5kVA 120v to 240v step up transformer that can be used to save on a split-phase inverter.
Yes, 15Amps 240v is plenty, my cabin never pulls over 1800watt, I only need the 240v for the mini split.
Yes, it's a poor man's solar, but it's getting there.
