Jamie.sanders
- Dec 1, 2019
- 159
I'm trying to calculate the size wire I need from my panels to the CC. but im not sure
how to calculate or what to calculate?
I know the specs of my panels
VMP 40.99
IMP 9.93
ISC 10.53
VOC 52.6
but do I use this or since my panels are wired 2S3P would I then use those power numbers?
Anticipated array power 2405 watts
VOC 105.2
Rated PV array current 29.79amps
battery charging current at 28.8v 91.7amps
If I should use the array numbers which ones?? or does array wiring not matter?
thanks in advance.
VMP 40.99
IMP 9.93
ISC 10.53
VOC 52.6
VOC 105.2
thanks in advance.
