heirloom hamlet
life my way
I am about to get the 280aH cells to make my 24v batteries with, and I ordered the marine fuse block and some fuses.
My question is, is it bad possible or bad to put a larger fuse on your system than is necessary?
I have four separate arrays and systems using 80a/60a MPPT All-in-one units. One system will be fed by (2250w) 3S3P 24v poly panels and charging two 24v 280aH LiFePO⁴ batteries. I got a 300a fuse for it.
The other two will be paired with (1500w) 3S2P 24v poly panels each and one 24v 280aH LiFePO⁴ batteries, and I ordered 200a fuses for them.
I've done my research and I know these fuses are a great fuse option and are necessary. My question is, can the fuses be too large for your system and either hurt it or do no good?
