opticalcarrier
- Feb 25, 2021
- 54
I have a Solark12k and want to add 3 of the EG4 battery systems that Will showed HERE to install on the floor under my inverter thats on the wall in the garage. If I keep each unit 12in from everything else, is 3 of these batts OK for code?
His link though goes to the wallmount version. I guess they have feet included if you want to put them on the floor?
Anyways, seems from reading the EG4 docs that these units already work with the Solark closed-loop communications protocol? If I want to parallel 3 of these to my Solark12K then this is all I need, right?
![1721254440042.png 1721254440042.png](https://diysolarforum.com/data/attachments/229/229357-39e16a9298a8a1b71d214606f7eba8b2.jpg)
Besides that, any suggestions before I pull the trigger here?
