I am having issues with my AC grid input to my hybrid inverter. So as a means of testing, I want to use my sub-panel which has a direct grid input from the main panel by installing a double pole 240V 30 amp breaker on the sub-panel and then connect that to the grid input of my inverter. Initially the inverter load breakers will be off and no wires connected to the load output of the inverter. This is just to see if the AC grid quality input is causing any inverter hiccups.
If the inverter remains stable with this grid connection, then I plan to connect the load into the sub-panel to the inverter's load connection. This would make it be: grid to sub-panel | sub-panel to inverter grid input | inverter load output back to sub-panel. Sort of a local loop with loads being powered this way through inverter. then I can test out grid powering loads, batteries powering loads and PV powering loads and grid and PV charging batteries.
Any thoughts on further isolating grid input qualities to inverter?
