douglasheld
Hello forum,
System Design
I have a Lexus HS250h. This car has a Toyota hybrid system similar to a Prius. The system includes a high voltage traction battery which is used to store energy for vehicle movement, and also a 12V AGM battery which is used to power on the control logic and high voltage relays, and provide utility power for things like lighting and the dashcam. As long as there's about 9-10V available from the AGM battery, the car can start. Otherwise, the 12V circuit needs an external power source (a jump) to turn the car on.
While the car ignition is "on", a DC-DC converter takes power from the HV battery and manages recharging of the AGM battery. So that means, when the car is running there's approximately 13.5V.
I've installed a dashcam. This Blackvue DR750X monitors voltage inputs from both the 12V battery connection and separately, the switched "ignition" signal which usually runs at the AGM battery charging voltage. When the ignition circuit goes to 0V, the dashcam monitors the voltage on the battery circuit and keeps recording motion events or accelerometer events until the battery voltage dips to 11.5V. Then, the dashcam powers off.
Problem Statement
Recently my car was damaged while parked, and this unfortunately happened in a 40 minute period when the dashcam had powered down. I really don't have any control over this design. I can choose the power-off voltage threshold and 11.5 is already the lowest setting. If I hack something to go lower, I run the risk of not being able to start the car, and that's a greater operational risk than losing forensic data.
I don't have any control over the car's design. The way the car was designed, it can sit unused for 4-6 weeks and there is still enough charge available in that AGM battery for the car to start. However with the dashcam added, it's now drawing the battery down to 11.5V within an hour or two of parking.
The idea is: If we have solar energy available, can I use that to safely extend the amount of time the camera can record in parking mode?
Proposed Solution
Use a battery isolator and a small PV panel under the rear window to recharge the AGM battery whenever the car is parked in sunlight. And so this isolator is going to have to be connected to that existing circuit, where the voltage available could be anywhere from a low AGM battery at 11.5V, or the DC-DC converter could be pushing 13.5, maybe 14+V during charging.
Questions
Since the battery isolator's design goal is to connect two batteries of different chemistry... does it actually make sense for me to repurpose that to connect two charging circuits to a single battery?
Is there an off-the shelf solution for my problem?
Can anybody see potential problems with my approach? (Note, the Toyota DC-DC converter is very expensive to replace)
System Design
Problem Statement
Proposed Solution
Questions
