I wasn't sure how to best write my title so I'll explain.
I have this inverter on hand; SunGoldPower SPH8K48SP, 8000W DC 48V UL1741 Pure Sine Wave Solar Inverter.
sungoldpower.com
It states that it is UL1741 certified but for off-grid only yet it also has grid-tied features to prevent back-feeding into the grid during a power outage.
This is confusing. Why would it be off-grid only rated or does it mean maybe they are still working on grid-tied certification also? I'll contact them.
Do different states have different requirements? For example, I'm in Arizona and already have a grid-tied system but most of the inverters are dead so I wanted to replace those with an all in one since I was grandfathered into that rating system for generating power.
During a power failure, grid-tied inverters simply stop putting power out so the safety is done at the inverter level.
Now, I share in image showing how my current certified setup looks. My intention was to connect the inverter AC to the same panel as the strings are tied to.
The thing is, I'm not sure if the meter next to the string inputs can also prevent power from getting back to the grid during an outage or perhaps there is something in the locked box that is also doing that? I wasn't watching when they did the final connecting.
Anyhow, my question is, is it possible to still use this inverter or do I have to find one that is grid-tied certified and if so, what would that UL number be?
Thank you.
![1717680528526.png 1717680528526.png](https://diysolarforum.com/data/attachments/220/220097-733aad36d5ee085651b1cf19ee17aae4.jpg)
![sungoldpower.com](https://sungoldpower.com/cdn/shop/files/01_8f8e53ab-c0e8-4122-94fe-32bc09d22d4b_600x.jpg?v=1697008632)
8KW 48V Split Phase Solar Inverter
Find the ideal 8KW 48V Split Phase Solar Inverter online from SunGoldPower. Experience superior quality and performance for your solar energy system.
![sungoldpower.com](https://sungoldpower.com/cdn/shop/files/favicon_180x180.webp?v=1682038397)
Thank you.
