Not sure if I'm misunderstanding what you are saying, but you don't need any other Victron devices to use the Blue Smart Charger. What makes you think you need other interconnected / required devices?
I actually prefer something like the Victron that lets you program it via Bluetooth. Most of the chargers like the one linked to above have a set charging profile that likely is not best for your LiFePO4 battery. For example, the only choice for 24V LiFePO4 in the one in post #5 above is a fixed voltage of 29.2V. That translates to the max 3.65V per cell, so it is certain that your BMS will cut off before all the cells are fully charged. Perhaps worse, there is no float setting, so it will hold the 29.2V level until you turn it off. Even if the BMS doesn't cut out, holding all your cells at 3.65V for extended periods is not good.
I should point out that I'm pretty sure the Victron IP65 Blue Smart Charger only supports 12V batteries. You'd probably have to go to the IP22 charger if you go with Victron, and that sounds like it is out of your price range.
