3 Years ago I converted a cargo trailer to a travel trailer. We have loved it and used it so much, I have decided to build a new one that has more space and has a more useful solar system.
My first trailer only has a 100 watt panel and a Renogy PWM Wanderer charge controller. Solar is used solely to keep my battery topped off between travel days, run the fantastic fan, lights, and charge our 12v electronics. The Battery goes to a PD4045 AC/DC Disribution panel that supplies all the branches with power throughout the trailer.
On the new trailer we want to have a full system that will allow us to easily boondock with solar or hook up to 30 Amp shore power in state parks. We want to be able to plug in to Shore power and not have to worry about transferring power manually from solar to shore power.
I started researching...several months ago. I found Will's Mobile Solar Power website and then this forum. I have learned so much, but feel I have a ways to go.
Here is what i am thinking: (I need advice and guidance! Please chime in)
1200W Array (3 200 watt panels in series then paralleled to another set of 3 200 watt panels in series)
Victron 100/50 Solar Charge controller temp sensor to charge controller (Battery temp for SCC) or is the one in the Battery sensor enough?
24V 300 AH LiFoPO4 DIY battery (Two of these) in series to an 8s 100Watt BMS.
Victron BMV 712 With Temp Sensor
24-12 volt converter
Victron Multiplus 24/3000W Inverter
Shore power will come into the Multiplus then out to the AC side of an AC/DC Power Dynamics Distribution panel.
Battery will go to the 24-12 Volt converter then to the DC side of the AC/DC Power Dynamics Distribution panel.
From the AC/DC distribution panel I will have all my branches from there to all my AC and DC loads.
From the negative lead off the battery, I will have a negative Busbar with the Victron BMV Shunt, solar charge controller, inverter then grounded to the chasis.
From the positive lead off the battery, I will have on a busbar, the fused charge controller then a battery cutoff, to the inverter, then to the DC side of the Distribution panel withe the 24-12v converter in between.
It is very much like this (Blue Print from Explorist.Life), but I need to put in the 24-12 volt converter somewhere, then I also need to make sure I have the right size fuses and gauge wires.
Things that I still am working out:
- What parts am I missing?
- Should I go with the Victron Multiplus? I go back and forth on using the Victron multiplus or just getting the items separately (transfer switch, converter, inverter, charger) Would it be cheaper? I am also a little worried on the complexity of getting all the items separately versus buying the multiplus.
- Where do I put the 24-12Volt converter? I believe between the Positive lead busbar and the DC side of the distribution panel.
- What size fuses and wires do I need through the system? Can I just use connectors and y connectors in the solar panel arrays with the series then parallel setup? How many feet can I go for the 10 AWG PV wire from the array to the charge controller, then from the controller to the battery. Controller will be within 2 feet of the batteries. Panels will be about 10-15 feet from the charge controller.)
