KnobCountry
Leg puller. Zap avoider.
What model is the epever? Sounds more like a pwm cc.My portable powerpack have a warning on it.
Max solar panel 80watts 24 volt on the mppt .
Strange the same connection is use to set a carlighter plug on it and than i charge with 10amps .
It draw 120watts on that moment.
So one mppt is not the same like a other.
My epever solar charger warning is that max 260watt by a 12 volt battery .
Do not go over it , it can damage the controller.
Its a 20amp model
In the Manuel.
On the victron 75/15 it tell max 220watt solar panel.
If its connect with more it will not use it but no damage.
