Dave911
Anyway, I am looking for a device to maintain (charge without damage) a 48 volt bank of LIFEPO4 batteries and also invert the power to 120 VAC when the AC is no longer available. This is pretty much the function of a UPS. But I don't need UPS switching speed. Why can't I find such a device that doesn't cost $800+ for 2000 watts? I want to be able to charge at 2000 watts and discharge at 2000 watts. I can find them with a 230 volt input and output (most of the world ignores 120 VAC) but everything at 120 VAC is expensive.
Before you say, buy a Chargeverter from EG4; I don't believe Chargeverters actually turn off the output in anyway. So as long as I have the Chargeverter connected and powered, I am applying volts to the battery bank. This is supposed to be bad for LIFEPO4 batteries, although I am not exactly sure why if the output voltage is not at the fully charged level - ie in the hockey stick part of the charging curve.
There will not always be a load on the inverter. It will be driving a small air conditioner which will switch on and off depending on temp.
This system needs to run unattended. So I can't babysit it. I'll be two hours away at least.
Any ideas? I thought about using a Solar AIO inverter but at the low price end the 120 VAC input and output is a problem with a 48 volt bank. I don't want to add an autotransformer so I can drive a 120 VAC load from a 230 VAC output inverter.
I don't have 230 volts available as an input, only 120 VAC.
I could go to a 24 volt battery bank if required. But even at lower voltages I'm not seeing what I want for a reasonable price.
Any ideas?
Any ideas?
