WolfbaneAries
- Sep 10, 2022
- 49
Currently I am using the charging settings recommended by Victron for my 48v Lifepo4 battery bank (3 sets of 16s 280ah cells):
Absorption: 56.4v
Float: 54.4v
I have read and heard a number of times that for maximum battery life (number of charge cycles), the batteries should be charged no more than 80% and discharged no more than 20%. Copied/pasted below is an example of such a chart (12v example).
It seems to me that my current charger settings get the battery closer to the 99% mark. What are your thoughts on charging only to 80% to maximize the lifespan of lifepo4 cells, and what Absorption and Float settings would you recommend to achieve that? At one point I was using 54.4v absorption and 53.6v float which seemed to get it into that 80% range, but then again it leaves quite a bit of power on the table that could be used when there are long stretches of cloudy days.
Absorption: 56.4v
Float: 54.4v
Voltage | Capacity | Charge Cycles | Lifespan (Above 80% Original Capacity) |
(V) | (Ah %) | (If charged and discharged to each of these voltages every day) | (Charged once a day) |
14.4V | 100% | 3200 cycles | 9 years |
13.6V | 100% | 3200 cycles | 9 years |
13.4V | 99% | 3200 cycles | 9 years |
13.3V | 90% | 4500 cycles | 12.5 years |
13.2V | 70% | 8000 cycles | 20 years |
13.1V | 40% | 8000 cycles | 20 years |
13.0V | 30% | 8000 cycles | 20 years |
12.9V | 20% | 8000 cycles | 20 years |
12.8V | 17% | 6000 cycles | 16.5 years |
12.5V | 14% | 4500 cycles | 12.5 years |
12.0V | 9% | 4500 cycles | 12.5 years |
10.0V | 0% | 3200 cycles | 9 years |
