Craigmck
- Feb 3, 2020
- 48
I have found out the hard way that when the Chargery bms shuts down because of a low cell voltage event. It only shuts down the discharge relay only. It does not shut down the charge relay, so when the bms shuts the battery pack down because one cell discharging down to 2.5v ( as the bms is programmed to). The charge relay is still active and is still pulling that 2.5v cell voltage lower. I discovered this problem this morning when one cell had dropped to 2.1v. When i unplugged the 8 cell wires from the bms the charge relay click off. Emailed Jason at Chargery today and he confirmed that in the event of an over discharge shut down, only the discharge relay is shut down. The charge relay is still active and consuming power.
I'm running 8 cell 3.2v 580ah lifepo4 from xuba in12v configuration. I believe 4s2p, 2 cells in parallel and 4 cells in series. I was doing a capacity test with 10 amp discharge rate. i only got 220 ah when the pack shut down because #2 cell bottomed out at 2.5v. the other 3 cell packs were at 3.00, 2.99, 2.98. Before this test i had done a proper parallel top balance. difference of .35mv.
Is there a better or more efficient way to build a 560 ah battery, or is it better to run two 12v 280ah packs then parallel for 560ah.
Thanks for any information.
