Hello,
I have a bore pump that runs off a local switch and is powered by 4x 34.3V 330W solar panels in series. I'm looking to make it so that I can remotely turn on the pump from approximately 5km away. Ill be using ScadaPack for the remote on/off and monitoring. I'll be using a 12V 50aH battery to power the ScadaPack, which I'm hoping to run off the solar panels that are already there. I'm looking for recommendations on what solar regulator / battery charger can be used with this high input voltage.
Thanks in advance.
Thanks in advance.
