OhYou_
Figured I'd make a thread on this.
I have a 7.5KW 120/208v battery backup ups unit that I got for nothing. It is normally set up with 10s of SLA batteries for 120vdc.
looks like going off discharge rate charts, it should operate in line with 38s of lifepo4.
Having a hard time finding a charger for this though. closest one i could find is this https://www.aliexpress.us/item/2251801616611891.html
if it is to be believed, that is some sizeable bit of kit, but obviously its nolabel so.
Does anyone have some suggestions on charging?
Or should I scrap the whole idea as not worth it? I feel the cost of a similar capacity 48v inverter outweighs the extra cost of a big bms and charge controller but idk. Saves a ton on all the little things related to moving around the power since I'm using way less wire size.
also some hidden benefits of just having a 120vdc circuit means I can just plug in a surprising amount of 120vac items in and run them on dc no problem. I was running laptop chargers and other switchmode psu stuff straight off the batteries just to try it. surely my induction oven wouldn't care either.
