I am thinking of making a big battery pack like 14s14p or so with the model 3 2170 cells.
1. What would the charging and float voltages be for my mppt? I have guessed 58.8 charge and 57 float but want to be sure. I'll be using a Victron 150/45 Smartsolar mppt most likely. I know that a full battery is 4.2v but 4.1 is recommended.
2. I will be using a 60a bms. These are safe to charge at 3a so isn't that distributed x 14 for parallel? 42ah charge rate?
3. What if I made 2 or 3 packs and put them in parallel for capacity. Could I hook up a charger to one end pack, or do I need to somehow split the charging (and discharging ) between the 3 packs. Seems like you could connect them all in parallel and then charge the top one. Similar to the titan.
Battery specs:
Voltage: 3.7V
End of Charge Voltage: 4.2V
End of Discharge Voltage: 2.5V
Capacity: 4800mAh
Nominal Stored Energy: 17.76Wh
Chemistry: Lithium-ion (NCA)
Internal Resistance: 12-14 mΩ
Standard Charge: 3,000 mA: CC-CV 100 mA cut-off
Quick Charge Current: 10,000mA
Max Continuous Discharge Current: 15000mA
Battery specs:
Voltage: 3.7V
Capacity: 4800mAh
