Watched Will Prowse video on using a resistor when connecting negative terminal from inverter to battery to avoid spark. He attached 25 w 30 ohm resistor between negative cable to battery, then touched other end to negative battery terminal. Then he said turn on inverter and try output. Not sure I understand. Does the inverter not have to be on when you do this?
