Hello, I'm hoping this is the right area to post this. Ive been having trouble with charging my 280ah 4s battery pack. I have a Daly 200ah smartBMS and a kisae dmt1250 charger. using the DC charge setting and wired to my vehicle's alternator, the charger ramps up amperage then cuts off to zero, then tries again and again. I checked my voltages and the 4g cable running from the alternator is not causing a voltage loss that would trigger the charger to cut off. I noticed though in watching the BMS that my "cell diff voltage would climb to 0.339v during charging and suspect that is triggering a protection that is currently set to 0.25v. If this is triggering, it only interrupts connection and does not shut off the battery. very intermittently the charging will hold for a bit (I have it set to 30ah) but eventually resets. How can I diagnose this? are there BMS logs that would tell me for sure if a protection was triggered?
The other possibility is the charger's bulk voltage is triggering the voltage overload protection. From the manual, the dmt1250 will output 14.6v but my Juntek monitor is only seeing 13.8v when these issues are occuring.
I did top balance my cells when I got them, they've only been connected as a pack for about 3 months now. Its a pain to take them all apart and rebalance them so I'm looking at installing an active balancer like the cheap one Will showed that blew up on him lol. or replacing my BMS with one that doesnt have the bluetooth issues i'm having and can active balance?
