I have a 510ah 24 volt Lifepo4 battery bank that is charged at 55 amps with the inverter/charger when needed. Takes about 9 hours 5% to 100% when charging with the inverter/charger. My solar panels are able to output through the solar charge controller at 90 amps to the battery bank, but that is for short periods during the day and 50 to 70 amps is normal while supply loads. So I charge with the inverter/charger in the lower range of the solar charge controller output to the batteries.
If your not in any hurry 60 amps is good, but certainly could charge higher (90 amps .15C) if your wiring and inverters can handle it without overheating for an extended period of time of charging. I have found that the temperature of my inverter/charger goes up quickly the higher the charging amps so if increasing go up slowly and watch temperatures. Also check the wiring and connections for hot spots.
