I just bought a houseboat and redoing all the wiring and installing a new 300amp lithium house battery. Currently the outboard (OB) via a stator charger which currently charges the starting battery (AGM). There is an auxiliary charging line that I can connect from my OB which is designed to charge a second battery like a house battery. I will be running that charging line thru a Renogy DC to DC / solar controller. The question is, if my starting battery dies and I need to start the OB from the house battery I will turn my battery switch to the house battery but then I will have both OB charging lines connected to be Lithium battery. One going thru the Renogy and the other coming directly from the OB. I believe I shouldn't do that correct? Hope that all made sense
