dudeinthewoods
- Apr 7, 2020
- 111
I've seen a few things discussed in different locations. I just did some testing so I'll clarify and hope this helps.
I've got a chargery 16T BMS
I'm running a 48v setup.
The relay output voltage is 12v on my 48v setup. I had read somewhere it outputs at system voltage. Not true.
The docs (that I read) said it should be voltage in so it seems some if not all their docs floating around are wrong.
