michael d
off-grid solar pilgrim
reported heat dissipation of a whopping power loss of 14.9 watts was a 200 amp Siemens NH type fuse for the rated power loss;
the 100-amp Siemens was 6.95 watts;
the 400 amp >>> Siemens brand NH fuse >>> its power loss at the rated amperage 27.5 watts power loss and rated up to 440-volt DC
600 amp fuse would be more wasted power at 600 amps>>>>> if you were pulling 600 amps; my suggestion would be to go with a 24-volt or 48-volt inverter so not pulling the higher amps...
I am starting the journey with the NH-type fuses for use in a stationary LiFePO4 build with 24-volt equipment...
minus 3 degrees Fahrenheit this morning with 16 inches of new snow the last few days ??
