Closed loop communication between EG4 Lifepower4 & Eco-Worthy AIO (re-badged SRNE HYP4850U)
Wolfpack7483
Charlotte, NC
I bought an Eco-Worthy AIO assuming it would be able to communicate with the EG4 battery. Reading through the manual, the list of battery manufactures available in the coms parameter does not include EG4. Is there an easy way to get closed loop communications between the 2?
An EG4 Communications Hub may be what you need. The hub acts as the "Master" battery and collects the data from all the EG4 LifePower4 batteries and provides communication protocol conversion from EG4 to several selectable protocols to communicate with the inverter.
Just verify the the EG4 Hub has a protocol you can configure in your inverters.
