I did a bad thing. I have 16 new 280AH CATL cells from Docan (Thanks Lily Zhang!!). after top balancing all 16 batts, i decided to load test 4 batts out of the bunch.
First battery made 301 AH, with a cutoff voltage of 2.5V. On the second battery, the damn cutoff voltage was somehow set to ZERO, instead of 2.5V !! NO INSTRUCTIONS come with these inexpensive electronic load testers, and there are subtle differences between brands, and how they operate.
After about 20 hours on the load tester at 20A constant current, I noticed the batt voltage was 1.5V instead of 2.5V and it has still NOT shut off !! It's then I noticed the cutoff was set for ZERO, instead of 2.5V. Sorry for the long story, thought it might help answer the question.
So, I'm recharging this individual cell, back to about 3.3V.
Several questions:
1. Will the case reflatten itself, as it recharges ?? I suspect the answer to this is NO. It is aluminum, it has deformed.
2. If the case will not reflatten itself, can I slowly "clamp" the battery back to having flat sides ?? After all, it is an aluminum case, and I'd think it would be possible to reflatten it, by clamping.
3. If I try to reshape the case by clamping, should this be done fully charged or discharged ?? I'd guess discharged, as there is less energey in the batt in case something shorts internally.
4. Will this over-discharge affect the life or capacity of this single cell ?? I would guess YES.
Incidentally, I will ask these same questions of Docan too.
Thanks for reading all of this and thanks for any inout !!
Bill
Several questions:
Bill
