Consumerbot3418
Fitting square pegs into round holes... for fun?
I'm trying to adapt to the Schneider Conext XW Pro 6848, coming from Victron gear. I was used to setting a single modbus register with a positive or negative number to indicate the targeted power to be drawn from or backfed into AC1. It seems to be a whole different paradigm with Schneider. I'm trying to work out how to get the XW to charge or discharge the battery by a specific amount. I found the EPC setting/register (external power control?), but it didn't seem to behave as anticipated...
(below discussion snipped from another thread)
I'm sure there are dependent settings and variables I'm missing, and I'm just struggling to figure out what the prerequisites are for charging or backfeeding (selling). It looks like, for selling:
I see it update on the Insight, so I know I'm writing the address correctly, but it doesn't always respond by charging or discharging at the rate selected--most of the time, it seems to just ignore it.What is the does it do and what are you expecting when you send to EPC charge?
- AC1 needs to be connected (duh)
- battery voltage/SoC needs to be over the threshold
- "Sell" needs to be enabled
- "Grid Support" switched on??
- need to be outside a "Sell Block" window
- battery forced to bulk?
- "Sell" disabled?
- to be outside a "Charge Block" window
I really appreciate you sharing that overarching description of your system, the obstacles, and thought process to get there. I'd seen your "mega thread" before, and it actually me inspired me to get the XW, after previously writing it off as being incapable of manual control. I doubt I'll end up going the PLC route, but between Home Assistant, Node Red, or maybe even Arduino, I'm confident I'll be able to make things work... once I figure out which registers I need to set! To summarize, your PLC is initiating charge with a forced bulk in the morning, controlling throughout the day via charge current, and then stops based on "Sell Block" time.What are the questions? What data do you need to make the decisions? What does each answer make you do?
How, exactly, do you stop the charge process?I only bother stopping the charge if the AC coupled Grid Tied solar falls to where the AC output of the XW-Pro starts consuming power.
This was a little tricky to understand, but I think I get it...As long as the XW-Pro is still charging at just 5%, it can't pull battery power to feed loads.
Looks like a pretty good application for a PID loop. Not sure how easy that is to implement in the PLC world, but I'll likely end up using one when trying to settle on my "target".I didn't like seeing it jumping around too quickly and certainly didn't like ever seeing it overshoot the desired current.
