From your schematic it appears that you intend 4 arrays (not strings since they will be wired to a SCC MPPT of their own) of 5 panels in series. (8000w) Each array you have labeled as 2000w and 48v. The 48v would not be an accurate Voc for 5 panels in series. 8000w could generate 40kWh a day or ~1200kWh a month if the sun is there.
In order to ascertain if your setup is viable the specifications for Voc, Vmp, Imp for the panels and the Voc and max PV current for the AIO's will need to be mentioned.
