Greetings everyone, I am in the process of squaring away my set up and at this point I think I pretty much understand everything within the system except for one part, the AC power.
Here's my set up I am planning to run with this inverter (https://renogy.com/2000w-12v-pure-sine-wave-inverter-charger-w-lcd-display/)
For the most part, the AC power will be primarily used to wire 3 outlets within the van as the rest of my items will be running to the DC breaker.
I have been trying to find the proper information but I can't seem to find the answer. Can I wire my 3 outlets directly to this inverter given it has built in protection or do I need to set up an AC distribution block and then connect to the inverter? If the latter is the answer, I would wire everything to the AC panel and then run the tri cable to the AC out on the inverter?
I appreciate any insights people might be willing to share, I don't know why I can't quite grasp the inverter piece of the set up.
Thank you!
Thank you!
