Hello all, I have a set up where the cables between the batteries are equal, and the cables from the positive and negative to the bus bar are equal, but they are longer than the ones that the are between the batteries. I think it's called split feed.
The other way is common point connection, where each and every cables is the same length and is connected to the Lynx, I know this is best practice for more even charge/discharge of the batteries.
My question is, is it that big of a deal how my setup is wired? Should I consider spending big bucks on cables? The longest cable is 3-4 feet, so I need to get another 4 new cables and a new bus bar..
Thank you!
Thank you!
