Daly 8s LifePo over voltage, temp error, act balancer
arjuna34
Portugal
Hi DIY solar forum,
Not so knowledgeable asking for over voltage and 3 temperature sensor error resolution.
System:
8s lifePo, Daly BMS, Active balancer, MPPT empever charge controller, 1500W/3000W inverter
Observations:
1. Soc >99%, 3.3V each cell
2. Inverter on --> beeping --> MPPT reads 26V -->12V --> 8V --> 13V --> 28V. Power output for half a minute --> then no more, beeping continues.
3. BMS high voltage protect 3.75 as suggested by maker
4. Regularly OVD warning on MPPT display
5. BMS 3 errors
5.1) Chg temp low lvl 2
5.2) DisChg temp low lvl 2
5.3) Cell temp error
6. T1 reads -40°C
7. Two days ago "upgraded" the system with active balancer.
To diagnose the problems and resolution procedure you guys can advice?
Pictures of setup included.
What you guys can advise?
Jacob here
