Whilst fitting my home made brackets, I have drilled a hole in to my new solar panel
I forgot to use the block of wood under the frame, and the drill bit went into the back of the glass.
It still gives a voltage, but I think this is probably due to the top part of the panel,
Is this going to cause problems, fire etc?
Do I open the box on the back of the panel, and unhook the bottom part of the panel so I can at least use half of the 445watts?
What do you think?
View attachment 109861 .
