I have 2 sets of panels mounted on opposite sides of a trailer roof so I want to use two separate SCC's to the battery as recommended by Will, and also want to take advantage of my Bluetti SoGen inputs. I am planning on one set 2P and the other 2S, but even if I wire both sets as 2S the same questions apply....
I want to switch my panel outputs from going to the 2 MPPT SCC going to battery, to going to the Bluetti SoGEN that has 2 MPPT built in to it. The Bluetti inputs are 15A max and 8A max. Can anyone recommend a proper switch to either switch each line separately, or ideally to switch all lines at the same time?
Finally, recommendations on what fuse sizes and where?
Thanks in advance!
Thanks in advance!
