Bud Martin
Solar Wizard
- Aug 27, 2020
- 4,833
3.5 cubic feet using 600WHr (0.6KWH) per day? That seems a lot.Yes, watt hours - size is 100 litres - which google says is about 3.5 cubic feet![]()
Compared to my experience with DC fridges, they would use about 400 per day. And the DC fridges I've used are half the size.3.5 cubic feet using 600WHr (0.6KWH) per day? That seems a lot.
Thanks for the data!!!
While your example fridge is too small, it does very much give one something to think about- especially at some point, the small compressors for small fridges will reach a min limit- so somewhere in the small size area, the compressor narrows down to one version.
So then the question becomes- how to shop for a 'fridge and an inverter that results in a very good result?
A side question- is there a simple accessible output that one can tap into to use as a fan switch? So that I can put a small 12V fan on the heat exchanger to help it work better? My DC fridge has that, and given it's put into a constrained place, that's a good (and cheap) thing to add.
For sure, if this fridge I have dies, I will lean toward a small AC fridge with an appropriate inverter.
BTW, setting up inverter vs. shore power would be as easy as a switch that goes between one and the other. Especially if it's a 3 way switch to allow the fridge to power down between inverter and shore power.
It uses only 300Wh per day? That means it consumes only 300W/24h= 12.5W each hour for 24 hours, that is really low power consumption.I recently bought a DC only fridge for a friend who was going off grid for a couple months and was able to test it for a month and I was shocked at how little power it used, it was consuming less than 300 watt hours in 24 hours off 2 6v batteries , less than 20% of batteries usable capacities. And as long as the sun was out I could have the battery fully charged back up with a 120 watt panel add a second one for most cloudy days .and this was during mid February - March .
This unit is a ever chill stand up fridge freezer combo ,not a full size refrigerator but still I think I could live out of it no problem. Its a lot bigger than a mini fridge.
Cost was just under 1000.00 from Amazon
Yep I was shocked when I looked at the watt meter , 2 - 6 volt lead acid batteries would run this unit for a week with no sun and when I hook up 2 - 120 watt panels whether its cloudy or not it tops the batteries off by the end of the day in March. Could not believe it. When I run my AC fridge and freezer the batteries are depleted in about 12 hours (I have never ran the fridge by itself to see how much longer it would run) In 12 hours thats about 1200 watt hours of use.It uses only 300Wh per day? That means it consumes only 300W/24h= 12.5W each hour for 24 hours, that is really low power consumption.
My home 20+ years 26 cu.ft side by side fridge uses 2080Wh per day measrued on the AC side of the inverter, so if factor in the conversion lost, I figure 2400WHr on the dc side of the inverter.I bou
I just checked the fridge size and it is 11 cubic foot size . Its not a small unit but its smaller than my fridge in the house but bigger than a mini fridgeMy home 20+ years 26 cu.ft side by side fridge uses 2080Wh per day measrued on the AC side of the inverter, so if factor in the conversion lost, I figure 2400WHr on the dc side of the inverter.
So to compare power consumtion based of cu.ft/Wh:
I.E. if 3 cu. ft uses 300Wh, then at 26 cu.ft, it will use 8.67 * 300Wh = 2601Wh.
Notes: 26cu.ft./3cu.ft = 8.67
That is not small size like those used in the dorm, it is really amazing that it uses so much less power.I just checked the fridge size and it is 11 cubic foot size . Its not a small unit but its smaller than my fridge in the house but bigger than a mini fridge
Yep thats it , it uses less than 300 watt hours in 24 hours and the highest amp draw has been 9.13 amps and while running its usually between 35 and 70 watts , when you first plug it in it will draw 112 watts for a minute but after that it stays between 35 and 70 watts but most of the time it is zero wattsI think this is the model:
The manufacturer's website, but it doesn't tell you much more than the Amazon page:
11 Cubic Foot 12 Volt Refrigerator, Stainless Steel
The Original 12V RV Refrigerator Upgrade your RV’s comfort and convenience with the industry’s first 12-volt refrigerator. Store more and keep your cold foods fresh with Everchill by Way’s 11 Cubic Foot 12-Volt fridge, the first engineered and designed for use in a recreational vehicle. The...www.wayinterglobal.com
The biggest factor is insulation. Followed then by compressor design. This assumes good condenser air flow.
If you have 8" if insulation on a 1,000l fridge it could use less power than a 100l fridge with 2.5" of insulation. Assuming you don't open the door or put warm food in it. About 1/3 of my fridge power consumption is cooling food thats put in it.
On the inverter side a low standby power inverter, or one switched by the thermostat will only add about 10-15% power consumption overhead.
However large inverters are not very efficient at low loads. My 3kw unit needs 400W of input to make 300W of output. While it only needs 2,100W to make 2,000W.
If you had a 100 watt light bulb and turned it on for 1 hour it would use 100 watt hours.Can you clarify the total number of watts used in 24 hours in your test? I'm confused by your use of watt hours.
The mfg says average draw is 6 amps. 6 amps per hour? If so, then ~72 watts per hour, 1728 watts per day or 144 amps per day. If those numbers are correct, that's an efficient refrigerator and I might consider it.
I was thinking of wrapping my little low budget AC fridge in an insulation wrap and trying aqain just to see.
