12VoltInstalls
life passes by too quickly to not live in freedom
For me - easy choice. Another $80 panel, additional $80 battery, $167 7CF 120VAC fridge. $330; done. And useable excess solar. And I don’t have some cooler taking up space
But if you already have a simple 100 watt or better panel, and a battery? I paid $192 for my cheap Chinese 12volt fridge. Takes up very little space, and consumes ~130 Wh per 24 hours. So, for less then your choice, you get the convenience of a portable fridge that weighs less than 30lbs. It's worth considering anyways. It's nice to have choices.For me - easy choice. Another $80 panel, additional $80 battery, $167 7CF 120VAC fridge. $330; done. And useable excess solar. And I don’t have some cooler taking up space
Please see my original post, and also a more recent one. I have been using both of my DC fridges extensively for the last year, as I have stated before. the argument that the compressor is cheap is compared to what? A $79 dorm fridge? really? My 50Ah rebel lifepo4 battery takes even less notice. I can run for at least 4 days without recharge, and no inverter needed. You Gotta factor in the cost of the inverter here.What size fridge? 3 quart?
You do realize that for that money, by default you most likely have the cheapest compressor assembly on the market?
Granted, if you use it only occasionally, it could last a few years. But under heavy use you get what you pay for rings true.
That said, if there is a consensus that the fridge you have lasts for at least 2 years under heavy use, then I'd probably buy one
Meanwhile, my 120Ah battery barely notices the 300wh overnight and my 2 solar panel can replace that easily and keep it going all day.
By all means keep us posted as to how much you use it and the failure date. haha
Please show us the make and model of your inverter, and how much you paid for it. That must be factored in., as well as the warranty. Please keep us posted as to how much you use it and the failure date. HaHaWhat size fridge? 3 quart?
Part of the reason we went with DC is the internal size- I can't recall the specific absorption fridge that would fit the same hole, but it was significantly less internal space, the one we got is 3 cu ft. On top of that, venting. Instead of having a vent to give fresh air and exhaust to the outside, we just have to have enough vent for cooling the coils.For you folks that are replacing an absorption refrigerator with a DC or AC fridge, how does the depth of the old and new units compare?
My Dometic RM2852 has a specified 24" depth. Many of the alternative refrigerators have a depth that is at least 1.25" more, while the width is an exact match.
Well your post surprised me cuz I agree with the above but in an entirely different direction. I understand your purpose snd if that’s what works for you- fantastic.Power efficiency is one part of the equation. Space to put stuff in is another.
Thats true enough for the positive ones, of course theres no reason for a seller to buy negative reviews, is there? They certainly are holding purchasers hostage over warranty service and negative reviews. It seems SOP is the product breaks, the seller doesnt answer phone calls or emails, purchaser posts a negative review, seller contacts buyer and offers a full or partial refund- depending on how long they had it- on the condition the review is removed or changed. The outside window seems to be a month or two, in fact a costway reviewer says their CSR outright stated the warranty was really 90 days.I still have two Massimo (Alpicool) China built LG compressors 54qt fridges operating 24/7 @ 32deg F for almost a year now on LiFePo and solar.
Never had a problem with operation.
So if your fat wallet needs some emptying go get ya a trendy box and you'll be in the club.
Both Massimos together cost less than 1 of those worshiped shiny trendy coolers and probably could have bought three and still spent less.
Bought at Costco so warranty is not a concern.
BTW, those Amazon reviews are regularly bought and sold...................
